1983 ELR R-2 engine
- Coyote
Re: 1983 ELR R-2 engine
07 May 2024 10:56
Me too, here's a new twist to the plot, the cylinders and engine cases are painted silver. The side covers are chromed, not polished.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
- gd4now
- Denco where did you go?
07 May 2024 11:28
I do not mean to make any reference to what engine numbers were stock on any of the ELR or SBR as the data I can find only indicates a starting number but not the total range. There appears to be some confusion as to how many of them were produced. I think this has been posted here before but for some more info check out this link
www.kz1000r.com/
or a page located there www.kz1000r.com/KZ1000R,%20R2%20and%20KZ...0Specification's.htm
As to the engine you have it would appear to be a J model engine which was used in several different models including the ELR and SBR models.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Coyote
07 May 2024 12:09
No problem gd4, I'm new at this and I need all the help I can get. I'll keep looking. It might not make any difference in worth even if it is. I don't know
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
- gd4now
07 May 2024 12:46
If I have left you with the feeling that I know more than you do, I DO NOT! Not sure why but for some reason I want to know more than I do. Did not mean to come across as you were wrong and I was right. Rather I for some very strange reason (I am not sure why) wanted to learn more and you have provided more data that may help with my quest. Again I thank you for it.
1977 KZ650 B1
- Coyote
07 May 2024 13:19
I didn't take it that way at all.
Thank you for sharing the data that I was lacking. I should have ended the subject with a question mark.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
07 May 2024 15:00
I wonder where kawguy got his info? If it is reliable, I’d love to have a copy. Maybe it will fill in some of the gaps I have in the file I posted in the inaccessible Filebase.
- Coyote
07 May 2024 15:04
I'm going to look that website back up and see if I can find the missing data that I didn't have. If I find anything I'll post it.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
- Coyote
07 May 2024 16:18
www.kawguy.com/frame--engine-numbers.html
I have no info on this site, it just came up on an engine serial number search. I can't find anything extra from what I already printed. I found the site to be questionable.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
The following user(s) said Thank You: TexasKZ
- sf4t7
07 May 2024 20:05
As for the chrome side covers, it was common in the 70's and 80's to get what was called a "chrome kit" for the Z1's KZ900's and KZ1000's where you "traded in" your covers toward the purchase of the chrome ones. I think they also offered a similar deal for the covers on the Honda 750's.
I put the chrome ones on my Z1 in the early 80's, and have recently converted back to the bare aluminum ones.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Coyote
07 May 2024 20:12
Cool to know. When you converted back to bare aluminum, did you get another set of covers or remove the Chrome from yours ? I got several chromed covers and forks and was wondering what the easiest way to de-chrome them would be.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
21 Z900 RS
Project 73 Z1
- sf4t7
07 May 2024 20:39
Replaced the covers with good used ones. The (40 year old) chrome plating didn't age well, and it's all peeling and pitted. I don't know of a good way to remove the chrome from aluminum. Blasting may not work well because the plating is harder than the aluminum under it. They've been set aside for some chrome removing experiments at a later date.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
07 May 2024 23:45A chrome shop will give you a price for strippingCool to know. When you converted back to bare aluminum, did you get another set of covers or remove the Chrome from yours ? I got several chromed covers and forks and was wondering what the easiest way to de-chrome them would be.
