New Clutch Pack Installation
- stepkitto
17 Apr 2024 15:42
Installed a new clutch pack in my 1981 KZ 440 A2. I followed the same order installing the friction plates and friction discs. I lined up the tabs on the clutch pack cover with the holes on the hub. My problem is trying to tighten up the four bolts on the clutch pack cover. It spins as I try to tighten it up and I tried putting the bike in gear but no help. The bike just moves and I cant get the bolts tight. I am sure there is a simple fix but I am not thinking of it. Any help would be appreciated !
- gd4now
- Denco where did you go?
Re: New Clutch Pack Installation
18 Apr 2024 10:01 - 18 Apr 2024 10:02
Not sure I totally understand the issue you are having. But if you do not want the bike to move as you try to tighten the bolts I might suggest pushing the bike forward until the front tire is against a wall or other object so it can not move and then tighten the bolts.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 18 Apr 2024 10:02 by gd4now.
The following user(s) said Thank You: stepkitto
18 Apr 2024 11:14
You could ask someone to sit on it and apply the rear brake
- stepkitto
18 Apr 2024 12:14
I figured it out. It was the clutch adjustment that was wrong. I backed the adjustment screw off until it was loose and this allowed me to tighten the bolts without the clutch moving. I am learning. lol ! Thanks for the advice !!
