1992 kz100p crank shaft inspection
  • Lpar
  • Lpar's Avatar Topic Author
15 Apr 2024 20:48
#897692
Just finished disassembling the engine on the police bike and have some questions on the crank shaft. All the main crankshaft bearings are good, but I'm concerned about the rod bearings. There appears to be a bit of a wobble to them, and not the side clearance, but a perceptible wobble on one or two of them. Is this the radial clearance described in the manual? I haven't put a dial indicator to it to check and see how far they're moving yet. I was checking the big end clearance by tapping on the top of the rod and there is a very small amount of movement felt but no metallic noise. It's hard to tell if the rod movement is up and down or side to side when I tap it. The bike was running before this, and there was bottom end noise but after tearing the engine down I found 2 of the 3 starter clutch bolts almost completely backed out, and the 3rd was broken, so that was definitely rattling around and making noise. If this crankshaft is bad, is it worth trying to find a used one on ebay? Or is it better to send it out?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: 1992 kz100p crank shaft inspection
16 Apr 2024 20:44
#897717
Might check these specs while you're at it...
www.kzrider.com/forum/2-engine/618672-cr...tion?start=24#881883
1982 KZ1100-A2/1170 sleeper 😀
