XR100 ring gap
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
XR100 ring gap
18 Oct 2023 12:48
#890623
Hi Guys. I am rebuilding a 1994 XR100 Honda trail bike. the manual says the ring end gap should be .020".
in the car world and Larger bikes i have done, the standard for setting end gap is .0035" per inch of bore. the piston in this bike is only 2 ". so it would be normal to set the gap at .007" for this . can anyone explain why honda would use such a large gap?
Thanks
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Nessism
  • Nessism's Avatar
Re: XR100 ring gap
18 Oct 2023 13:13
#890624
.020" sounds like a "service limit".  Do you have the real Honda manual, or a Clymers (or similar)?
As a datapoint, the Suzuki GS250 twin, 125cc/cylinder, lists the spec as .004-.012" for "new" rings, and .028" as the service limit.
  • mark1122
  • Keep twisting it
Re: XR100 ring gap
18 Oct 2023 13:27
#890625
You R way Tooo SMART.  And sooo right. I just rechecked the Honda manual. It is indeed the service limit. It makes sence now.
Thanks
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
