Driven Cam Damper
  • Youngblood
  • Youngblood's Avatar Topic Author
Driven Cam Damper
06 Oct 2023 10:27 - 06 Oct 2023 14:56
#890155
Ok been reading a lot about the transmission today and found a driven cam damper attached to the gearbox is this to smooth out the shaft drive??
Sorry this on a Z1300 engine
Last edit: 06 Oct 2023 14:56 by Youngblood.
  • Youngblood
Re: Driven Cam Damper
09 Oct 2023 02:26
#890247
My suspicions where correct the Z1300 has a damper on the end of the driven shaft and in the gearbox to smooth out gear changes and shaft drive, so if the drive shaft train is removed there will be no need for this part as well making it a whole lot easier for my conversion.
  • TexasKZ
  • TexasKZ's Avatar
09 Oct 2023 04:23
#890249
Yes, they are to dampen vibration and harshness, which is why chain drive bikes have a damper in the rear wheel.
  • Youngblood
09 Oct 2023 05:16
#890250
Correct
