Will a 87-88 head gasket fit an 82 KZ305
  • ckahleer
  • ckahleer's Avatar Topic Author
26 Sep 2023 14:58
#889806
Pics of them look identical, but they have different part numbers.
The 87-88s are easer to find than for a 82.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Will a 87-88 head gasket fit an 82 KZ305
27 Sep 2023 11:49
#889838
They may look the same but be careful of the "thickness" too thick will give low compression, too thin will give high compression but reduced piston to valve clearance
