Need confirmation that timing is set wrong on my 1976 KZ900
- Rolf1976_KZ900
Re: Need confirmation that timing is set wrong on my 1976 KZ900
22 Sep 2023 14:24 - 22 Sep 2023 14:43
HaHa that is cool i will note that in my old mechanical trick book .well since you used 2 on each side your bike is worth 4 dimes more! i had to google the dime and found it was a picture of Roosevelt on it. I have been on the aircraft carrier roosevelt taking off and landing ,but it is not what you may think because i was 5 or 6 year old and it was in a chopper
Last edit: 22 Sep 2023 14:43 by Rolf1976_KZ900.
- Rolf1976_KZ900
22 Sep 2023 14:29
A little more is done tonight the head and barrels are off could not see anything nasty.I found some black broken pieces that i will try to fish out so minimal fall down into the case
i will post some picks tomorrow .
22 Sep 2023 14:42
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
22 Sep 2023 14:47
SWest that is interesting a hinge ?
22 Sep 2023 15:00Trap door to prevent oil starvation if you get excited in the curvesSWest that is interesting a hinge ?
22 Sep 2023 19:39
The following user(s) said Thank You: Wookie58, Rolf1976_KZ900
- Rolf1976_KZ900
23 Sep 2023 12:29
Done some more today since i cant take the engine out where i live now i will just overhaul the head and cylinders and replace timingchain and slider plus rollers sprockets.
After some inspections the conrodbearings feels solid .The crank rotates very easy i can rotate it with my fingers on the 17mm nut with minimal force.That is when pistons is off
I would like to test the crank for runout and also the bearingclearances ,but then i have to split the cases and that is not possible this time. I measured the conrods sideplay and it was inside spec.I fished up some more black hardened rubber pieces i think it is from a O-ring but not sure .If someone know where it is coming from tell me !
23 Sep 2023 15:05
This doesn't belong here
This does
The roller won't even fit the pin unless someone removed the needle bearing.
This does
- Rolf1976_KZ900
24 Sep 2023 02:37
Hi Steve i saw your post last night and did not understand what you talked about .This morning im still tired and a little confused ,but i se now what you mean.It for sure looks like there is a needlebearing on the side there! that is very strange .All the rollers are out now and i will take a look at them. the bike is taped and ready to be picked up and sendt to a winterstorage.
I will se if i have more pics or video from down in the case.
- Rolf1976_KZ900
24 Sep 2023 02:56 - 24 Sep 2023 03:07
Update i now had a quick look at some more photos and it is not a needle bearing it is the big sprocket that is connected to the clutch It looks like a part of a needlebearing in the pickThat was posted earlier
By the way is there supposed to be a o-ring where the red arrov points ?
Last edit: 24 Sep 2023 03:07 by Rolf1976_KZ900. Reason: text
- zed1015
24 Sep 2023 03:34 - 24 Sep 2023 13:31No!
And if if there is one and it managed to get pushed up the stud by oil flow and block or restrict the feed up to the head it will cause the cams to run dry and wreck the shell and cam journals.
Last edit: 24 Sep 2023 13:31 by zed1015.
- Rolf1976_KZ900
24 Sep 2023 09:19
Ok thanks zed1015 then i know that .On my fj there is some green O-rings on the outer studs where the oil flows so thinking maybe kawasaki had something similar.
I then need to find out what the o-ring pieces coming from .The tacho drive has 2 O-rings and they are intact and soft.They was replaced 2019 when a kawasaki dealer replaced them i can se from a resiept from po owner. Maybe the pieces is from a old oring on the thachodrive that was not seen when the dealer replaced them.
