cams not aligned on TDC
- Fox
05 Aug 2023 01:10
Hello,
I'm looking for a click what i think to be from a bad timing.
Rework the timing yesterday and i can see that the cams are not aligned when 1/4 are on TDC.
When i set the 2 timing marks on TDC (picture 1) then the cams are positioned like the first image of the second picture (with top idler on)
To have them aligned like the second image of the second picture i have to pass the TDC form 5mm to the left.
I that normal because those bikes are old or did i make something wrong ?
Best,
Fox
Best,
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Warren3200gt
Re: cams not aligned on TDC
05 Aug 2023 01:17 - 05 Aug 2023 01:19
Looks like a 900?
The timing marks are very faint. They are highlighted in yellow on the workshop manual diagram. If your cams are not as the workshop diagram then they are installed incorrectly. Your picture doesn't show the exhaust cam timing mark but looks like it could be 1 tooth out so the inlet will be also.
Last edit: 05 Aug 2023 01:19 by Warren3200gt.
The following user(s) said Thank You: Fox
- zed1015
05 Aug 2023 03:04
Possibly a tooth retarded on the crank.
A more detailed pic of your actual cams at TDC would get a more decisive answer.
- Fox
05 Aug 2023 03:33
I can't have the first pin of the cam (number 0) chain aligned to the front timing mark. Must be above or below. I chosed above.
The inlet cam look to be not aligned. The exhaust one is good.
I actually think to replace my cam chain. But before gonig on this job is that a trick to correct this trouble by "advance or retard" the timing to know if it's the problem ?
I have a kz1000 ltd 78 and dyna s ignition. Perhaps play with it or give more space for the exhast shims...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Warren3200gt
05 Aug 2023 05:09
Pin '0' will be slightly below. Set it up so that at tdc the exhaust cam mark is as close to level with the head surface as you can get it. Ensure the chain is tight from the crank to the cam. This may be slightly above level with the head if your timing chain is worn/stretched. Pin 1 is the first pin after the timing mark. Then 28 pins back to the inlet cam mark.
- zed1015
05 Aug 2023 05:53Set the zero pin ( which will also be the exhaust timing mark ) to which ever pin is closest to the head surface at TDC whether it be slightly above or below .I can't have the first pin of the cam (number 0) chain aligned to the front timing mark. Must be above or below. I chosed above.
If the pins are equidistant from the head surface then use the one slightly below.
