- Thank you received: 20
Wiseco 810… to sleeve or not to sleeve?
- rangeroy
17 Aug 2023 07:40 #888374
by rangeroy
1977 z650
Replied by rangeroy on topic Wiseco 810… to sleeve or not to sleeve?
1977 z650
- slayer61
- KZR FLAG RELAY CARRIER #62
17 Aug 2023 08:13 #888385
by slayer61
Replied by slayer61 on topic Wiseco 810… to sleeve or not to sleeve?
says The board requires you to be registered and logged in to view this forum.look here
How to make a set of liners for you 810 pistons. - 750turbo.com
- Injected
- Thank you received: 538
17 Aug 2023 11:35 #888401
by Injected
Replied by Injected on topic Wiseco 810… to sleeve or not to sleeve?
MTC use to offer a 67mm = 761cc kit (+1mm) and a 68mm = 784cc kit (+2mm) they do sometimes come up on Ebay and here (bought a NOS 761mm kit off a member on here 3 years ago)I have a Wiseco 810 kit in my garage, but I've held off because my stock engine is running great, and I don't like the fact that the liners will be so thin. I wish there was a 2mm over kit, or even a 1mm kit, which will leave the liners thicker. Maybe this a moot, and just something that sticks, needlessly, in my head, but i'd prefer a kit that left the liners thicker.
- Thank you received: 2817
17 Aug 2023 18:08 #888418
by Nessism
Do you still have that 761cc kit?
Replied by Nessism on topic Wiseco 810… to sleeve or not to sleeve?
- Injected
18 Aug 2023 12:30 - 18 Aug 2023 12:32 #888461
by Injected
I always recommend MTC over Wiseco as they are made from better materials. My other go too would be JE.
Yes, I have a 750 barrel bored and honed to take it, its going in a fuel injected project I have in the works. I got a excellent deal on here from a member in New Mexico, it was just the pistons, rings, and pins.
Last edit: 18 Aug 2023 12:32 by Injected. Reason: sp
The following user(s) said Thank You: Nessism, Street Fighter LTD
- stone fruit
- Thank you received: 10
20 Aug 2023 23:45 #888547
by stone fruit
Replied by stone fruit on topic Wiseco 810… to sleeve or not to sleeve?
I've been using the Kawasaki 750 sleeves in my 810 bigbore Z650 for over 10 years now, first with the high compression Wiseco's & now with low compression for a draw through turbo.
I lived in a tropic climate and started using an oil cooler but eventually removed it and no longer use it but I have an oil temp gauge.
The is another big bore option now available which is the Bagus Omega 850cc big bore kit with liners.
Bagus! motor cycle | KAWASAKI ZEPHYR 750 OMEGA PISTONS (bagus-mc.jp)
