Visual difference between GPZ & KZ cams
  • Elfarm98648
  • Elfarm98648's Avatar Topic Author
19 Jul 2023 14:20
#887418
For the KZ750, a common modification is to change out the GPZ cams for a higher lift and longer duration to change the powerband on a KZ750. I found what may be a good deal on a set on Fleabay however I want to make sure I’m buying GPZ cams and not a set of standard KZ cams especially when there’s nothing wrong with mine. I’ll add the eBay item number and hopefully someone more versed in the KZ750 internals can tell.
eBay:
295815656968
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Visual difference between GPZ & KZ cams
19 Jul 2023 15:29
#887425
Not sure about the 750 but the manual for the 1000/1100 has details of the identifiers for all the different versions
  • TexasKZ
  • TexasKZ's Avatar
19 Jul 2023 15:58
#887426
Here is what the fsm has to say, which ain’t much.
  • Nessism
  • Nessism's Avatar
19 Jul 2023 16:13
#887427
The cams in question are claimed to be from a 1982 GPz750.  As I understand it, those cams have the same lift and duration as the regular 750 cams, only they don't have a tach drive.
  • TexasKZ
  • TexasKZ's Avatar
19 Jul 2023 16:38
#887429
The fsm says the GPZ makes a few more horsepower than the other versions. If the cams are the same, I wonder where the other ponies came from. Could the BS34s really make more power then the Keihins?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
19 Jul 2023 16:58
#887430
GPZ/ZX 750/1100 cams have more lift and duration.
  • Nessism
  • Nessism's Avatar
19 Jul 2023 17:07
#887431
GPz has more compression, better flowing carbs, and the bath tub head.  And I'm not sure, but I think the exhaust flows better.
The following user(s) said Thank You: TexasKZ
  • Nebr_Rex
  • Nebr_Rex's Avatar
19 Jul 2023 17:19
#887433
Bingo!!!! We have a winner.
The Uni Tracks got the bigger cams except for the '82 GPz1100, which had 8 degrees more duration than the '81 model that has standard 'J' cams.
I do not know what the difference in lift is.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
19 Jul 2023 17:23
#887434
I do believe the bathtub head has a little small chamber.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Franklin
  • Franklin's Avatar
19 Jul 2023 19:06 - 19 Jul 2023 19:13
#887436
Something I found from another thread. When they say "real GPZ cams"  they mean '83-'85 because as mentioned in '82 they were the same as KZ750 performance-wise; from what I've read '82 GPZ lobes were wider (not taller) and no tach gear on exhaust cam:
"The easiest way to identify the real GPZ cams is to just measure the lobe height.
Just use a vernier caliper to measure the complete lobe on the cam.
If it is 36,15 mm (1,424 inch) high, you have the wrong (standard) cams...
Inlet should be 36,65 mm (1,444 inch)
Outlet should be 35,65 mm (1,405 inch)
They were only installed on the GPZ750A1 - A3."
I've asked a seller to measure the lobes when I wasn't sure what year they were. I will also mention the good GPZ750 cams are getting hard to find, lots of KZ750 and '82 GPZ out there but not '83-'85 GPZ.
Last edit: 19 Jul 2023 19:13 by Franklin.
  • TexasKZ
  • TexasKZ's Avatar
19 Jul 2023 20:29 - 19 Jul 2023 20:32
#887439
Indeed. If you take a look at the 1983-85 supplement in the back of the fsm, the specs clearly show a change in 1983, compared to the numbers posted by Nessism above. See pages 343 and 358, for example.
www.kzrider.com/modules/ServiceManuals/GPz750.pdf
Last edit: 19 Jul 2023 20:32 by TexasKZ.
  • Elfarm98648
19 Jul 2023 21:41
#887440
So what I gather here is that in order for the cams to be any different than the ones I have, they need to be from a 83-85 GPZ A1-A3. and the only way to tell is have the lobe heights measured and compare them to the specs given by Franklin. The seller claims they come from a 82 but that’s based on the engine serial number since he got the engine only and matched the GPZ title back based solely on the serial number. Likely not the cams I’m looking for unfortunately.
