Will not start
- 1980Ltd1000
Re: Will not start
24 Jul 2023 17:33
So the exciter was removed.
now I’m still puzzled.
Checked the coils per specs and they came out fine.
Battery was checked, said it was fine but tonight I charged it and it was very warm. Maybe the battery is actually garbage but test and loads out fine?
Still completely puzzled here….
Re: Will not start
25 Jul 2023 00:03
Did you check the supply voltage to the coils both static and when cranking the engine ? I would suggest the following
- Check battery voltage ( should not drop below 9.5v - 10v when cranking)
- Connect voltmeter red lead to battery + and black lead to supply side of coils (Looks like a red wire ?) reading should be no more than 0.5v when ign on and kill switch set to "run"
- With the voltmeter still connected as above crank the engine and note the readings
- F64
- 81-KZ440D2
Re: Will not start
26 Jul 2023 15:06
Check your spark timing for each coil.
Your spark could be advancing or retarding.
81-KZ440-D2.
LIC, NY
LIC, NY
- 1980Ltd1000
Re: Will not start
19 Feb 2024 11:59
I replaced the DYNA S and the bike started right up and ran. It was the DYNA S the whole time. Dyna even told me it wasn't, SO MUCH FOR THEIR TECH PEOPLE.
- usa forever
Re: Will not start
27 Feb 2024 22:09
Just a side note, all the ground comes from the cable that bolts on your rear motor case with a 10 mm bolt. This cable is a crimp cable over solid core ,stretches, gets brittle and loosens but the bike runs .But when you fire your 29s up with a lot of flow it can't get enough spark then you can start chasing your tail. Glad you got it right now. You still might check your cable if it's original.
. Thanks for your help sharing with us all .
. Jim
. Jim
