Kz650 b3 no compression on 2 and 3
Re: Kz650 b3 no compression on 2 and 3
23 Jun 2023 03:57It's not intended to be relevant to timing Wookie. So far no proper compression test has been done. That should be the first step in diagnosing the problem.I'm not sure of the relevance regarding timing given that a compression test is purely mechanical and carried out with all the spark plugs removed ?
I suspect after such a long lay-up (and with the plugs being oiled) the the rings are stuck. Perhaps a good soaking with WD40 or similar overnight (don't forget to spin it over with the plugs out to clear the excess) may release the rings and recover the compression loss.
To faceplateman...have you checked to ensure your cams are in their correct location and not reversed? Just thinking out loud on this one. I don't know if that would cause your problem but it's a check that you could do before pulling the head off.
23 Jun 2023 04:50AgreedIt's not intended to be relevant to timing Wookie. So far no proper compression test has been done. That should be the first step in diagnosing the problem.I'm not sure of the relevance regarding timing given that a compression test is purely mechanical and carried out with all the spark plugs removed ?
The following user(s) said Thank You: hardrockminer
- faceplateman
23 Jun 2023 13:52
Yes i will check that the cam shafts are in the right position. And this weekend i will go and get a proper compression tester and a leak down tester because i think that would help too.
1979 kz650 b3
23 Jun 2023 17:15A sensible investment, they don't have to be expensive (you don't need professional quality equipment for things you will only use maybe once a year or less)Yes i will check that the cam shafts are in the right position. And this weekend i will go and get a proper compression tester and a leak down tester because i think that would help too.
As an "aside" sticking your thumb in the hole is not the best idea for the same reason you shouldn't put an air line blower against your skin - with in excess of a 100psi of cylinder pressure (potentionally) you run the risk of introducing air bubbles to your blood stream which will ruin your day
- faceplateman
27 Jun 2023 22:13
Ok so i just tested the compression test here are the results.
Test done with engine cold, all spark plugs removed and the throttle wide open.
#1=90psi
#2=0psi
#3=0psi
#4=110psi
Idk if thats good for a cold reading.
i also looked at the exhaust valve clearance on 2 and 3. 2 was at .45mm and 3 was at .17mm
#1=90psi
#2=0psi
#3=0psi
#4=110psi
1979 kz650 b3
28 Jun 2023 00:44
You could do a “leak” test to see where 2 &3 have lost all pressure but guess with 0 readings it’s time to get the spanner’s out (did you try soaking overnight to release the rings?)
28 Jun 2023 03:43
Yup! Time to take the head off and have a look. The clearance on #2 is much more than spec. Not sure what impact that would have.
- faceplateman
28 Jun 2023 10:41
Yes i tried soaking everything overnight. It did not work.
1979 kz650 b3
- Warren3200gt
28 Jun 2023 10:54 - 28 Jun 2023 11:02
Even 1 & 4 is way low. 650 motors should have a hot compression of 160 - 180 psi which cold would be 140 plus.
For 2 & 3 to have 0 you must have a valve hanging open or worse. 2 & 3 always wear faster and run hotter due to lack of cooling air. A super lean mixture for a long time will put holes in pistons 2 & 3 first. Are the exhaust header pipes on 2 & 3 very blue compared to 1 & 4?
If it were me I'd strip down the complete top end and check EVERYTHING, your past hoping a soak/adjustment quick fix.
Last edit: 28 Jun 2023 11:02 by Warren3200gt.
- faceplateman
28 Jun 2023 14:27
Yes im past that. My plan now is to remove the head and rebuild it completely.
1979 kz650 b3
- faceplateman
28 Jun 2023 14:29
I should note that the tester i used was a 25 dollar Pittsburgh tester i got from harbor freight. The hose attachment didnt even work so i used the straight tube with the rubber cone on the end. Even then i had to push pretty hard to keep a seal on the gauge.
1979 kz650 b3
28 Jun 2023 14:53
Due to the large valve clearance and zero compression, i bet you will find some bent valve stems on #2 and #3
The following user(s) said Thank You: faceplateman, Warren3200gt
