Kerker Quiet Baffle
  • racerx311
  • racerx311's Avatar Topic Author
Kerker Quiet Baffle
30 May 2023 08:15 - 30 May 2023 08:16
#885405
I recently bought a 1977 KZ1000A1  w/Kerker exhaust system.  It has the Kerker Quiet baffle.. My Question:  Is this a 2 piece baffle?  Can the Quiet system be removed from main 1.5" Kerker baffle??
Last edit: 30 May 2023 08:16 by racerx311.
  • TexasKZ
  • TexasKZ's Avatar
Re: Kerker Quiet Baffle
30 May 2023 10:56
#885410
So far as I know, Kerker never made two-piece baffles. You have a choice between one of the three baffles offered, or a straight pipe.
The following user(s) said Thank You: racerx311
  • sf4t7
  • sf4t7's Avatar
30 May 2023 21:56
#885450
Back in the day, the first thing we did to a Kerker was remove the fiberglass from around the baffle.  Otherwise you'll have to change to one of the other baffles as TexasKZ stated.  My choice was the race baffle, I think it was 2 1/2"
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • MotorcycleMechanic86
  • MotorcycleMechanic86's Avatar
08 Jul 2023 14:25
#886987
You can take the fiberglass packing off from the baffle. I’ve also cut down the baffle itself a couple inches. You also can get a competition baffle or run without one.
  • urankjj
  • urankjj's Avatar
08 Jul 2023 15:58
#886991
The whole subject is quite baffling, you could say that I'm completely baffled. Though I have heard that the path of least resistance is the easiest one to follow.....
