clutch lever cable
  • MALCOLMHOULE
  • MALCOLMHOULE's Avatar Topic Author
clutch lever cable
27 May 2023 17:37
#885300
the nipple broke off the cable … new cable is in the mail.
is this a difficult job - replacing the cable?
  • hardrockminer
  • hardrockminer's Avatar
Re: clutch lever cable
27 May 2023 19:09
#885304
Normally no.  You will need to remove your drive chain case, and likely your left foot peg and shift lever.
The following user(s) said Thank You: MALCOLMHOULE
  • Nessism
  • Nessism's Avatar
27 May 2023 21:52
#885311
An impact driver helps remove the engine cover screws
  • hardrockminer
28 May 2023 04:05
#885314
Excellent point!  I was thinking that the cover is fastened with M6 bolts, but some may use M6 screws.  You will need to buy a proper screwdriver called JIS standard.  Otherwise you can easily strip the screws with a Phillips screwdriver.  Vessel makes really nice impact JIS screwdrivers.
  • sf4t7
  • sf4t7's Avatar
28 May 2023 04:54 - 28 May 2023 04:56
#885315
The Vessel screwdrivers are reasonably priced , I found mine on Amazon
And I agree with Nessism, get the impact type
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 28 May 2023 04:56 by sf4t7.
  • Nessism
  • Nessism's Avatar
28 May 2023 07:53
#885324
I love my JIS screwdrivers.  They are a must for sure.  That said, for engine cover bolts, a standard #3 phillips head bit, as supplied in most common Impact Driver kits, work just fine for the engine cover screws.  Don't try #2, that's too small.
