APE nuts
- TerryK
APE nuts
27 May 2023 15:56
Hey dumb question: you guys using oversized head studs on 900/1000s, how do you seal the outside four nuts so they don’t piss oil? These are the open top nuts, not the closed ones.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Re: APE nuts
27 May 2023 16:17
Re: APE nuts
27 May 2023 20:46
I'm using the stock ones with new copper washers.
- Injected
Re: APE nuts
28 May 2023 07:26
I have seen those aftermarket black nuts with the open tops. Those are mostly for drag racing.
Use new copper washers that are tight to the studs and smear some RTV on the threads before torquing them down, you should be OK.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- Cra-z1
Re: APE nuts
28 May 2023 10:31
I use the closed nuts along with the APE cylinder studs. I use new copper washers and spray them with a light coat of Permetex copper spray. For a street bike I would not use the open nuts on the outside studs
- gd4now
- Denco where did you go?
Re: APE nuts
29 May 2023 12:35
It must be the 11 year old in me, but when I first read the tittle of this topic I first thought of these two pictures before I realized just what the topic was about.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: daveo, sf4t7
- Wheelhop
Re: APE nuts
29 May 2023 15:21
Ha Ha, me too!
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
Re: APE nuts
29 May 2023 23:19
- daveo
Last edit: 31 May 2023 20:12 by daveo.
The following user(s) said Thank You: SWest, Wookie58
- sf4t7
Re: APE nuts
31 May 2023 21:08
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Dr. Gamma
Re: APE nuts
31 May 2023 21:52
Unfortunately MTC doesn't make them anymore. The only cylinder studs I have ever used in my motors were the MTC Golden Studs. They are the exact dimensions of the stock studs but just made of a better metal. I also use copper washers on all 12 studs. If I reused some old ones I always annealed them and made sure they had a smooth surface where the head nuts came in contact with them. On the four outer washers I applied a thin coat of Three Bond TB-1211 on both sides of them. Never used anything but the stock head nuts. Never saw the need for those fancy cylinder head nuts!! Somebody in the late '80's did sell some Titanium copies of the stock head nuts. The price was crazy so I passed on buying them. I always follow the factory torque pattern in the shop manual and I never use more than 31 pounds of head torque. I never suffered any type of head gasket leaks or oil leaking from those outer studs.
1986 RG500G 2 stroke terror.
- Injected
Re: APE nuts
01 Jun 2023 05:33
The APE nuts/studs are for racing, you can torque them to +45 FT LBS they are for high compression applications. You don't need them for a street bike.
They only offer them in black because racers don't need chrome.
