KZ problem and stalling after a minor accident.
- KevinCullen
Re: KZ problem and stalling after a minor accident.
21 May 2023 11:09I would think that after checking the vent there is not much else left to check.
Running the petcock with the fuel tank cap off is another way of verifying the cap vent.
You've pretty much narrowed the culprit down to the petcock.
As TexasKZ mentioned there may be something stuck inside.
Thanks. I was a little shocked because the petcock was changed a little before the accident. Not even 6 months ago, and it was working fine. The bike tank area wasnt damaged at all, and the petcock wasnt touched. but i guess all things are possible. I just cant see how it would have stopped working.
In your opinion, is there anyting in the carbs that could have caused allllll of them to stop delivering fuel, as a result of the impact when the bike fell on the engine guards - it was a pretty hard fall.
21 May 2023 12:01
Sounds like you have narrowed it down to the petcock. It not supplying enough fuel to support the volume needed to continue to allow the bike to run. Something was dislodged inside the tank or the impact from the wreck broke something in the petcock.
In your opinion, is there anyting in the carbs that could have caused allllll of them to stop delivering fuel, as a result of the impact when the bike fell on the engine guards - it was a pretty hard fall. Yes the petcock. It runs on an auxiliary tank.
21 May 2023 12:13
Bit of a random question but what colour is your 650? ( is it green by any chance?) do you have pics?
The following user(s) said Thank You: riturbo
- KevinCullen
- KevinCullen
21 May 2023 12:21Bit of a random question but what colour is your 650? ( is it green by any chance?) do you have pics?
Its a 1978 and its blue. For some reason, this site wont let me post pics. It says "you do not have permissions to view this page."
21 May 2023 12:29
How are you trying to attach the pics ?
- KevinCullen
21 May 2023 12:31 - 21 May 2023 12:43
I got into attachments. Im going to try it now and see if it works. If is does i guess it will show below. this is a pic of it when i first got it. I added engine guards about 6month later. they were kinda hard to find.
Last edit: 21 May 2023 12:43 by Wookie58.
21 May 2023 12:35 - 21 May 2023 12:44
Looks a pretty solid bike, when you have attached your picture click "insert all" for it to show full size (wait for the green text to appear) I have fixed this one
Last edit: 21 May 2023 12:44 by Wookie58.
- KevinCullen
21 May 2023 12:41
Thank you for the info. I had been meaning to join this site since I got the bike but never got around to it. With my new problem I figured it was the perfect time.
- KevinCullen
27 May 2023 14:53Had some time to work on the bike today. Put the new pingel petcock on and took the bike out. Got two miles and it died. Friend picked me up again. Looked at the spark plugs and they are fine.How are you trying to attach the pics ?
The bike only seems to idle when the choke is on. So, carbs?
- F64
- 81-KZ440D2
27 May 2023 15:08
did you ever check the voltage?
As far as electrical.
fire the bike up and put a volt meter on the battery terminals.
note voltage
raise rpm to 3000
note voltage
raise rpm to 5000
note voltage
voltage should stay from 13-14.6
note voltage
raise rpm to 3000
note voltage
raise rpm to 5000
note voltage
81-KZ440-D2.
LIC, NY
LIC, NY
- KevinCullen
27 May 2023 15:27Yes. Sorry, I forgot to say. The voltage all checks out fine and the charging system works properly. The problem I think is in the carbs. . I hope nothing in the carb body was damaged even though the bike fell on the engine guards.did you ever check the voltage?
note voltage
raise rpm to 3000
note voltage
raise rpm to 5000
note voltage
