Advise for getting stripped, seized and in general completely fucked bolt out?
  • Jon99
  • Jon99's Avatar Topic Author
18 May 2023 13:15
#884860
There's this bolt in the cylinder head of a Z400 from 78. Probably best you take a look for yourself:
Much appreciated
Jon
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Advise for getting stripped, seized and in general completely fucked bolt out?
18 May 2023 13:44
#884861
Try to hit it with an outside multi tooth nut socket that bite into the left over of the philips head.
The power of the impact will loosen the thread binding too!!
  • TexasKZ
  • TexasKZ's Avatar
18 May 2023 13:46
#884862
Yikes. I would start with  heat. A heat gun will be less risky than something with a flame. Get it quite hot, then let it cool a bit, then pour on some Kroil or Liquid Wrench ( they are by far the best penetrants) and use it liberally around where the flange meets the head. I would do this a couple of times a day for several days.
It looks like the top of the nut has been drilled. If you can see the end of the stud, filling that cavity with penetrant will also help.
it looks like the nut is completely round. If not, a high quality six point impact socket on an impact gun, or even a hand impact wrench, may be able to grip it well enough to get it loose. If it is really round, then you may want to skip the penetrant and go straight to a Dremel tool with a cutoff wheel. Be very careful that you do not mess up the threads on the stud.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
18 May 2023 14:20
#884865
TexasKZ, it´s a allen head screw (not a philips head, stupid me). In Germay we have more form and function related names and not manufacturer/brands related.
skip to 3:51
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 May 2023 14:43
#884868
If you have access to a MIG welder you could weld a hex nut to the top of it (the heat from the welder will also help)
The following user(s) said Thank You: Warren3200gt, Dragbike_Mike
  • TexasKZ
  • TexasKZ's Avatar
18 May 2023 18:48
#884885
My apologies, I thought I was looking at a head nut.
  • hardrockminer
  • hardrockminer's Avatar
18 May 2023 20:01
#884889
The first thing I would try is to remove the bolt with these pliers.  As already mentioned, use heat first.
www.amazon.ca/VAMPLIERS-Linemans-Extract...a-383525757080&psc=1
  • TexasKZ
  • TexasKZ's Avatar
19 May 2023 14:15 - 19 May 2023 14:18
#884936
Since it is a bolt instead of a nut and stud as I previously thought, you could just drill the head off, remove the cover or head or whatever you are trying to remove, then you will have the remaining part of the screw sticking above the surface. Lots of penetrating oil and heat and some high quality vice grips should do the trick.
If the threads are not too buggered, you may also be able to thread two nuts onto the remaining part of the bolt, jam them together and screw it out.
Last edit: 19 May 2023 14:18 by TexasKZ.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
19 May 2023 15:16
#884941
I use left handed drill bits on those. Most of the time the bolt unscrews just before the head pops off. If it doesn't the head comes off and you proceed like TexasKZ said.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Rick H.
  • Rick H.'s Avatar
25 May 2023 08:46
#885178
So Jon99, what did you end up doing to remove said item???
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Nerdy
  • Nerdy's Avatar
  • Away
25 May 2023 09:21 - 25 May 2023 09:23
#885181
Put a large-ish center punch in the middle of the screw head and hit it with a proper hammer, like a heavy ball-pein.
The impact will help to jar the fastener loose, and the theory is that the concentrated force (of the pointed punch) will be directed along the shank of the fastener and will reduce some of the tension caused by the slight stretching that occurred when the screw was installed.
Also if you're planning to use Vise-grips or similar, put an Allen wrench in the screw head first. If you just squeeze it with the locking pliers, you may deform or break the screw head - that would be less than helpful. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 25 May 2023 09:23 by Nerdy.
The following user(s) said Thank You: slmjim+Z1BEBE
  • Rick H.
  • Rick H.'s Avatar
03 Jun 2023 04:56
#885548
Guess Jon left the building....
Rick H.
Rick H.
