KZ1000p throttle won't turn
- penguinphan
03 May 2023 15:35
Hi guys, looking for some more help. I have a 1995 KZ1000p and I can't get the throttle to move at all. I tried adjusting the throttle cable play, but no matter where I set it, the throttle won't budge. Has anyone run into this before? Is there an easy fix or am I going to have to get a new throttle body? Thanks!
Re: KZ1000p throttle won't turn
03 May 2023 15:50
Have to ask, did you switch/reversed the open and close cable eventually?
- penguinphan
03 May 2023 17:06
That is a great question that I would answer if I had any idea what you said means.
03 May 2023 17:16
If it were my bike I'd first remove the gas tank, trace the throttle cables, disconnect the cable at the carbs to see if the throttle shafts moves, etc, etc. In other words, do some basic troubleshooting.
- Kelly E
03 May 2023 17:21
When it won't move it's one of two things, the cables are crossed or the throttle shaft is seized.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- ronnieV
04 May 2023 06:45
Has the bike been sitting long,are things rusty? Like previous post say it's time to dive in,start the diagnosis.
