What oil should I use?
  • MLMG
  • MLMG's Avatar Topic Author
  • See you in the wind.
26 Apr 2023 15:18
#883795
Hi everyone, my A1 has a newly assembled engine.
All seals and clutch discs are modern.
For the first use, I used mineral oil, which I plan to change after a few kilometers. My question is, should I stick with mineral oil or switch to synthetic oil?
Thank you.
1977 Kawasaki KZ1000 A1
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: What oil should I use?
26 Apr 2023 15:49
#883796
We use 15w/40 diesel truck oil, it has the correct additives for our old school motors. Rotella T4 is a great choice.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: Nessism, MLMG
  • Nessism
  • Nessism's Avatar
26 Apr 2023 16:16
#883797
 I also use diesel oil.  Some people will be along shortly saying that you MUST use MA certified oil, because otherwise your wet clutch will be damaged, but I don't believe that.  The low viscosity oils, 30 weight and below, often times have friction modifiers, and those can get to your clutch, but typically, 10W-40 or thicker oils won't, so the big worry about clutch damage is overblown.
The following user(s) said Thank You: MLMG
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
26 Apr 2023 18:16
#883800
What does the manual or cap say?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • TexasKZ
  • TexasKZ's Avatar
26 Apr 2023 19:48 - 26 Apr 2023 19:52
#883804
The manual and cap were published before synthetic oils were widely available. The manual also says nothing about modern tires, blade fuses, et cetera. Many things have improved since the 1970s.
Any modern oil, without the extra friction modifiers, is in every way better than the best oils available when KZs were new. Synthetic oils are better at resisting shear and heat degradation than non-synthetics. This seems to me to be of special importance in air cooled engines that have the transmission in the sump.
Another consideration is the reduced levels of zinc and sulfur and the effect that has on flat tappet wear.
I prefer a motorcycle or diesel specific full synthetic.
Last edit: 26 Apr 2023 19:52 by TexasKZ.
The following user(s) said Thank You: Wookie58, MLMG
  • hardrockminer
  • hardrockminer's Avatar
26 Apr 2023 19:54
#883805
I use Rotella T4 15W40.  I believe it's Jaso certified.
The following user(s) said Thank You: slmjim+Z1BEBE, MLMG
  • Mikaw
  • Mikaw's Avatar
26 Apr 2023 19:58
#883806
Rotella T4
  • sf4t7
  • sf4t7's Avatar
26 Apr 2023 20:23
#883807
I use Kawasaki KPO conventional 10w40 in my 74 Z1A.  I think it's made by Motul.  I've also used Rotella T4 15w40.
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
27 Apr 2023 00:14
#883811
The easiest way to choose a motorcycle oil, no matter where its used, is to buy it from a dealer in a container saying its for motorcycles with the weight thats noted in the manual or on the cap. Guys want to save a buck here and buy Walmart oil, diesel oil, etc its not necessary.  Personally I would never use non moto oil in my bikes or recommend it to others.
1975 Z1 900
2004 KX125
  • MLMG
27 Apr 2023 10:29
#883847
Based on the comments, I conclude that mineral, semi-synthetic or synthetic oil can be used as long as the viscosity of the 10W-40 oil is respected.
  • Nessism
  • Nessism's Avatar
27 Apr 2023 10:39 - 27 Apr 2023 10:42
#883848
The manual doesn't mandate 10W-40.  The chart below is from the 750 manual, but other manuals are similar.  I'd stay away from the thicker stuff if you are riding in cold weather, though.
Last edit: 27 Apr 2023 10:42 by Nessism.
  • BCScott
  • BCScott's Avatar
27 Apr 2023 18:14 - 27 Apr 2023 19:55
#883866
I've had my A1 since 1979. I've always used Castrol 10W40 motorcycle oil. It's readily available to me and reasonably priced. I change it every 5,000 kms. The bike is at 88,000 kms now. My service manual states SAE 10W40.
Back in the saddle and loving it! KZ1000A1
Last edit: 27 Apr 2023 19:55 by BCScott.
The following user(s) said Thank You: Kidkawie, howardhb, MLMG
