Cam chain sprockets check
- Fox
19 Apr 2023 15:01
Hello,
i'm looking on my 3 cam chain sprockets.
I have one : nothing is moving inside. (back one)
I have one : the metal center pin can roll imself (top one)
I have ome : all metal parts can move themself inside (front one) -- (For this one it can be easy to remove the center pin with a finger)
Is that normal or they are worn ?
Best,
Fox
Best,
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
Re: Cam chain sprockets check
19 Apr 2023 15:14
If anything other that their axles rotate or move independantly of the sprocket they must be replaced or repaired.
The following user(s) said Thank You: Fox
- Fox
19 Apr 2023 15:26
Ok so the center axle must rotate
i have one like this. : good
I have one where all parts moves : worn
what about the one wehre the center axle don't move ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
19 Apr 2023 16:45
Better to replace but not important...
I mean the cam chain sprocket just turn around the idler guide...
Whatever it turn ones (just the sprocket) or twice (the sprocket and the centre axel) or 3 times (the sprocket the centre axel and the other metal part inside.)
It's just worn and i have to think to replace the last one but can be used like this for the moment... no ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
19 Apr 2023 17:02
Personally, I think the risk is too high. If it fails, the result could be a destroyed engine. Since the engine is already open, now is the time to replace them all. Take a close look at the chain, too. Measure it for stretch to be sure it is not also needing to be replaced. Liska makes excellent replacement sprockets.
- Fox
19 Apr 2023 17:26
if you pinch the central axis between 2 fingers the sprocket only rotate or the other parts also rotate?
For sure i have to ckeck the one who don't have the centre axel rotate ...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
20 Apr 2023 01:16 - 20 Apr 2023 04:11
The idler sprockets have a needle roller bearing in the middle.
Only the axles should rotate in the bearing .
The rest of the sprockets are bonded together and should behave as one piece.
If any other part or sleeve etc moves independently the idler is faulty..
Last edit: 20 Apr 2023 04:11 by zed1015.
- Fox
20 Apr 2023 13:32
Yes. On the 3 have one is working like that. One good.
One have a little play but it can do the trick for the moment. I will replace it in future.
One i can remove the inside with a finger so i replace this one.
Is it possible to see if the top idler is worn or not ? I have the oem one with the pin.
Is it a way to remove this pin? Do i need to drill it ?
Also how to know if my cam chain need to be replaced ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
20 Apr 2023 13:44 - 20 Apr 2023 13:45See page 143 of the factory service manual for chain specifications.Yes. On the 3 have one is working like that. One good.
kzrider.com/modules/ServiceManuals/Kawas...Service%20Manual.pdf
Last edit: 20 Apr 2023 13:45 by TexasKZ.
