RUBBER PLUG,CYLINDER 92074-030
  • Fox
  • Fox's Avatar Topic Author
19 Apr 2023 06:42
#883431
Hello,
i don't find the information on the manual so i ask here :
I have 4 round rubber plugs for the cylinder.
Where do they go ? I have 4 holes in the center (around the chain) or 4 holes on the front of the cylinder...
And what are they for !
Thank you :)
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Cra-z1
  • Cra-z1's Avatar
Re: RUBBER PLUG,CYLINDER 92074-030
19 Apr 2023 07:59
#883433
They go at the base of the cylinder, 8 of them , 4 in front and 4 in back if I remember right. The ones you have are probably hard as a rock and won't do to much I think mainly to keep dirt and stuff out of those holes and maybe for vibration at the Finn's. You can buy them here. I go down to Ace hardware and grab some tapered rubber plugs and cut them to fit snug
www.cmsnl.com/products/rubber-plug-cylinder_92074030/
The following user(s) said Thank You: Fox
  • MLMG
  • MLMG's Avatar
  • See you in the wind.
19 Apr 2023 14:02
#883453
My Kawasaki KZ1000 A1 only has 4 rubber plugs on the front of the cylinders, apparently just to prevent dirt from accumulating in that area of the crankcase.
1977 Kawasaki KZ1000 A1
  • Fox
19 Apr 2023 14:41
#883455
Yes same here : 4
I will Put them on front.
Thank you !
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Mikaw
  • Mikaw's Avatar
20 Apr 2023 06:27
#883477
Not the expert here but I have heard the are a factory item installed to suppress vibration durning the original manufacturers boring process. Beyond that they are not necessary.
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
20 Apr 2023 12:41
#883491
When i restored my Z, one year ago, i renewed them just because my engine was open and i had the rubbers laying around. And yes, the old ones where hard as rock. I think they where just to prevent dirt.
