torque wrench settings
- collin 618
18 Apr 2023 09:09
Would anyone be kind enough to detail the torque wrench settings on a Kawasaki GT 750
Mains
Big ends
Head Thanks in advance
Collin
Mains
Big ends
Collin
Re: torque wrench settings
18 Apr 2023 11:28
Look in "articles" at the FSM for a KZ750 and all the specs you need will be at your fingertips
The following user(s) said Thank You: Nessism, collin 618
- collin 618
22 Apr 2023 08:18
Thanks for that, I managed to find a manual on a KZ750 E that seems similar other than the shaft drive. I’m reassembling an old 1980’s Gt750 that I bought in boxes. I am currently rebuilding the gear box.
the main shaft/drive shaft has 3 small bearings that seem to lock the fist gear selector in place and I’m struggling to get the box to change up and down are the bearings thrown out with centripetal force to allow the selector to move.
im struggling to see how else these function.
once again thanks in advance
regards
collin
regards
collin
- krazee1
22 Apr 2023 10:07
You are encountering the neutral finder function, as you surmised the shaft needs to be spinning so centrifugal force will throw the ball bearings out of the groove.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- collin 618
23 Apr 2023 08:34
Thanks Mike
I did not want to assemble the whole engine without running the box up and down I assume I could spin the drive shaft with a slow drill but was hoping there was a simple way of proving the box before assembly
23 Apr 2023 10:23
You can use the starter motor to spin the internal gears. Removing the spark plugs let spin the engine much higher.
- collin 618
