Skimming a Z1 head on a mini mill
- Injected
13 Apr 2023 14:18 - 13 Apr 2023 14:29
I had to fly cut a Z1 head last summer for a drag bike build.
All I have at home is this mini mill and I knew it was a bit too small but I also had to fix some exhaust stud holes (drill out at tap for M8) so I needed to make a fixture for that anyways.
Got to thinking I could use the fixture plate to clamp the head to the table as the table is very narrow. A quick measuring with a tape measure showed me I could cut one half of the head at a time then sand the cut transitions flat on a 3/8" piece of glass with some sandpaper glued to it
This is the drilling fixture - It fits both 650/750 and Z1 heads.
Fixing the stud holes
Indicated flat to within .001" when clamped for cutting.
2" fly cutter head
Finish sanding setup
removed .035" to achieve 34cc chambers afterwards (valve seats sunk back)
Final result
37/31 mm - 105 CFM port job on intake side, Jerry Branch style porting enlarged.
2" fly cutter head
Final result
1978 KZ650B2 modified project
Last edit: 13 Apr 2023 14:29 by Injected.
- Nebr_Rex
Re: Skimming a Z1 head on a mini mill
13 Apr 2023 17:37
Nice job,....the mother of invention.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
