Is it possible to use a kz 1000 Shaft crankshaft?
  • MLMG
  • MLMG's Avatar Topic Author
  • See you in the wind.
10 Apr 2023 12:26
#882864
Hello everyone.
I have a question, is it possible to use a kz 1000 Shaft crankshaft in a kz1000 A1 and upgrade the alternator at the same time?
1977 Kawasaki KZ1000 A1
  • zed1015
  • zed1015's Avatar
Re: Is it possible to use a kz 1000 Shaft crankshaft?
10 Apr 2023 13:28 - 10 Apr 2023 13:33
#882867
The 1980 ST ( with kickstart ) crank ( same as MK2 and B model LTD's ) will fit the 1000 A1 with some slight mods
The crank sprocket has an extra tooth (16) so you will need the matching ST/MK2 cam sprockets (32t) and the longer 124 link camchain .
You will also need to use the ST/MK2 alternator cover to accomodate the later alternator.
Last edit: 10 Apr 2023 13:33 by zed1015.
The following user(s) said Thank You: Mikaw, MLMG
