after tipping valves, much needed valve shim sizing help
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
07 Apr 2023 21:48
#882652
currently on #2 ex there is a 2.20mm shim and clearance shows a whopping .55mm
so what shim would i need for achieving a clearance of .20mm
#4 in  have .30mm clearance and a 2.40 shim
I believe I'm looking for clearance to be about @ .15mm to .20mm
#3 ex has clearance of .35mm with a 2.40 shim
looking to achieve about .20mm to .25mm clearance
any help is certainly appreciated
thanks
1982 KZ1100D1
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: after tipping valves, much needed valve shim sizing help
07 Apr 2023 22:01
#882653
Add 2.20 plus .55 gives you 2.75 - .15 = 2.60. and so on.
The following user(s) said Thank You: Nessism, Gdailey2112
  • zed1015
  • zed1015's Avatar
08 Apr 2023 01:49 - 08 Apr 2023 03:58
#882657
If this is for a KZ900/1000 you need 0.15mm valve clearance for stock cams ( up to 0.17mm max ).
0.18mm for Unitrack cams..
Then a max of 0.20mm for race cams.
0.25mm is miles to wide.
To calculate your shim size just add the current clearance to the shim size and deduct 0.15mm.
So for #2 add 0.55 mm clearance to the 2.20mm shim = 2.75mm and deduct the 0.15mm clearance required and you get 2.60 shim needed.
255 shim for #4
260 shim for #3
Last edit: 08 Apr 2023 03:58 by zed1015.
The following user(s) said Thank You: Gdailey2112
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Apr 2023 18:32
#882744
You'll have plenty of adjustment room for years of more rides. Good job.
  • Gdailey2112
  • 82 KZ1100D1
08 Apr 2023 19:48
#882750
i wanna thank you guys
that info really helped
but not just for now, no no
...that was a tid bit of very handy & useful information that will last me for a lifetime
I really do appreciate all the much needed help
thank you, thank you, thank you
1982 KZ1100D1
  • sf4t7
  • sf4t7's Avatar
12 Apr 2023 16:08
#882987
Thanks from me also, I'm in the process of calculating shim sizes for my 1974 Z1A.  I'm "reviving" -- it's been asleep for the last 22 years, now I'm retired and needed a project
2nd owner, I've owned it since 1977
Work done in 1981:
1015 bore kit
Andrews 1X cams
welded crankshaft
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
