LH exit 4-1
- mvent
LH exit 4-1
01 Mar 2023 17:43
Looked at a rough 76 KZ900 today that had LH muffler 4-1, could not see any markings, maybe Denco? Any others exit on left side?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: LH exit 4-1
01 Mar 2023 20:22
Look at the hanger bracket Denco will have HBE stamped on it.
The following user(s) said Thank You: mvent
- mvent
Re: LH exit 4-1
02 Mar 2023 15:46
If all goes as planned I should have it tomorrow and will report what it is.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- Dr. Gamma
Re: LH exit 4-1
02 Mar 2023 17:51
Back in the day J&R made a copy of the 900/1000 Kerker pipe except it exited on the left side of the bike.
After 40 or so odd years my memory is a little fuzzy but I do kinda recall it being on the left side of bike.....
Its the very same J&R that made the expansion chambers for the Kawasaki triples.
1986 RG500G 2 stroke terror.
- Injected
Re: LH exit 4-1
03 Mar 2023 05:18
There are a lot of pipes sold/made out of the UK that exit on the LH side, seems to be popular over there. Maybe something to do with kick start lever clearance?
1978 KZ650B2 modified project
- gd4now
- Denco where did you go?
Re: LH exit 4-1
03 Mar 2023 09:42
Agree left hand Alpha systems from the UK were good sounding and working systems, In the past there was a long topic/post here that had lots of pics of different exhaust systems, but it appears that most of the pics have been removed at some point, Anyway here is a link to the post.
kzrider.com/forum/2-engine/271747-header...-header-pics?start=0
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- mvent
Re: LH exit 4-1
03 Mar 2023 11:30
Didn't go as planned. Bike has been sitting in a shed since probably mid 2000's, kryptonite type wheel fork lock with no key, fork locked with no keys to bike. Never saw so many rodent droppings and nest, even the engine was covered in nest and dead small animal remains all around it, really disgusting. Everything had some rust and engine covers and block looked white from oxidation. Can't imagine there's anything left to wiring. Good news one owner with title, engine turns over. No air box or original exhaust, but extra original paint tank in decent shape outside inside needs work but not soft anywhere. Owner passed recently and needs to be removed, I'm thinking of asking young guy across the street to cut off the locks and power wash nest off for couple of hundred bucks and give it another go.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: LH exit 4-1
03 Mar 2023 11:46
Steering lock is only one small flat head to remove the cylinder fron the lower triple. You can remove the front wheel and set forks on a dolly. Might be a jem in disguise.
- Wheelhop
Re: LH exit 4-1
04 Mar 2023 13:02
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
The following user(s) said Thank You: Nessism, Wookie58
- gd4now
Re: LH exit 4-1
04 Mar 2023 14:06
Good idea...... bike doesn't roll no problem.
1977 KZ650 B1
- mvent
Re: LH exit 4-1
06 Mar 2023 15:02 - 06 Mar 2023 17:0876 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: 06 Mar 2023 17:08 by Street Fighter LTD.
Re: LH exit 4-1
06 Mar 2023 15:22
Hanger looks correct for a Denco. It would be there monocone pipe. If that the bike you claimed sat it looks pretty nice
