95 KZ1000p not starting - I think it's flooded
  • penguinphan
  • penguinphan's Avatar Topic Author
28 Feb 2023 13:43 - 28 Feb 2023 13:45
#880878
So I've run into a new issue (old issue) with the 'P'.  I can't get it to start and I think it is flooded.  I looked at the petcock and I don't see an 'off' position.  Only 'On', 'Res' and 'Pri'.  Is there a way to shut off the fuel?  The switch is always in the On position.  I assume that 'Res' is 'Reserve'.  Is 'Pri' Primary? Thanks for the help.
Last edit: 28 Feb 2023 13:45 by penguinphan. Reason: picture attached multiple times
  • zed1015
  • zed1015's Avatar
Re: 95 KZ1000p not starting - I think it's flooded
28 Feb 2023 13:55 - 28 Feb 2023 13:58
#880879
It's a vacuum operated tap.
The PRI position means PRIME and is to supply fuel to the carb prior to the engine being started at which point you should switch to ON or RES depending on the fuel level in the tank..
Fuel should only flow when the engine is not running with the tap in the Prime position.
On and Res shouldn't flow any fuel until the engine is running so either will act as off when the engine is not running.
If fuel flows through ON or Res with the engine not running the tap is faulty and at the least the diaphragm will need replacing..
Do not leave the tap in the PRIME position when the bike is parked up or garaged as this may cause flooding.
Last edit: 28 Feb 2023 13:58 by zed1015.
The following user(s) said Thank You: penguinphan
  • penguinphan
28 Feb 2023 14:21
#880881
Thanks for the info.  I will try starting it in the Pri position.
  • penguinphan
28 Feb 2023 14:30
#880882
No luck.  Still won't start.  Almost sounds like there is no fuel getting to the engine.  Looks like it is going to go back to the shop.  :(
  • F64
  • F64's Avatar
  • 81-KZ440D2
28 Feb 2023 14:47
#880886
Grab some starting fluid and see if the bike fires.
Before you do that, pull the plugs.
Do they smell like gas?
Does your oil smell like gas?
81-KZ440-D2.
LIC, NY
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
01 Mar 2023 05:56
#880923
Is the tap flowing? Is there fuel in the carb bowl? Easy to check...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
