What are the reeds?
- Will2000
What are the reeds?
21 Feb 2023 14:21
I have a 1983 kz1100, and noticed some reeds on the top of the engine (that what the parts diagram calls them). they have a tube coming off the top but it looks like the previous owner capped them of. No idea if they are important for a vacuum system or anything. If you know what they are let me know!
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: What are the reeds?
21 Feb 2023 14:23
Emission control stuff. If they're capped off, and you aren't MOT'd or anything, you'll be fine.
The following user(s) said Thank You: Will2000
- Will2000
21 Feb 2023 14:35Thanks! No, I dont have any inspections or anything in my state so that is good! the tubing to cap it is kind of getting cracked so I will replace it with some fresh ones and call it good, thanks for your help.Emission control stuff. If they're capped off, and you aren't MOT'd or anything, you'll be fine.
21 Feb 2023 14:39
The following user(s) said Thank You: slayer61, Will2000
- slayer61
24 Feb 2023 07:21FIFY!
The following user(s) said Thank You: Wookie58, Will2000
