How to change valve seals without disassembling the cylinder head …
  • increasing
  • increasing's Avatar Topic Author
  • curious to know
Re: How to change valve seals without disassembling the cylinder head …
18 Feb 2023 04:36 - 18 Feb 2023 04:39
#880371
There are several points that must be successful when pressurizing the cylinder while changing the valve seal, so you have a good point there «DFIGPZ» When disassembling the cylinder head, you have both opportunities to check more details and make improvements :)
increasing :)
1974 Kawasaki Z1A 900, 1976 Kawasaki KZ900-A4, 1987 Kawasaki GPX750R
Last edit: 18 Feb 2023 04:39 by increasing.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Feb 2023 05:00
#880372
Not sure if you saw the edit to my last post ref pressurising multiple cylinders to prevent rotation - ultimately a full strip would allow re-seating of the valves and inspection of the chain idlers but it is " do-able"
  • increasing
  • curious to know
18 Feb 2023 06:11 - 18 Feb 2023 06:14
#880376
Yes, I read your post and it is possible to run pressure on two cylinders at same time … You also don't have to dismantle the exhaust and carburetors.
increasing :)
Last edit: 18 Feb 2023 06:14 by increasing.
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
18 Feb 2023 08:15
#880383
I lock the rear wheel by stepping forcefully on the rear brake pedal, then take a piece of tie wire and tie the pedal down (usually to the frame) in that position.
For tie wire I use #12 solid copper insulated electrical wire.
  • howardhb
  • howardhb's Avatar
  • God, I trust
19 Feb 2023 03:49 - 19 Feb 2023 04:59
#880420
Seen my dad do the "rope" trick on car engines. Never failed.
H.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
Last edit: 19 Feb 2023 04:59 by howardhb.
