KZ650 head swap
  • Pat L
  • Pat L's Avatar Topic Author
KZ650 head swap
12 Feb 2023 08:57
#880050
Hello,
Does anyone know if a head from a 1977 Z650C will fit straight on to a 1980 Z650F1 ?
Not sure if the F1 still has its original  engine, the numbers on the F1 start with KZ650BE######,
The 1977C engine numbers start with KZ650BE######  ???
Any help appreciated ,
Thanks.
  • azman857
  • azman857's Avatar
Re: KZ650 head swap
12 Feb 2023 09:14
#880051
It should. And you lose the emission ports and can use the smooth valve cover. A KZ750 head have slightly bigger valves..
The following user(s) said Thank You: Pat L
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: KZ650 head swap
12 Feb 2023 15:28
#880082
Yes, but vise versa a later HYVO cam chain head didn´t work on a earlier roller cam chain head (missing top idler sprocket mounts).
  • azman857
  • azman857's Avatar
Re: KZ650 head swap
12 Feb 2023 19:09
#880099
Yes, you would have to use the cams from the original head. I knew I was forgetting something....The rubber block of the later covers, wouldn't fit in the earlier valve cover would it?
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: KZ650 head swap
12 Feb 2023 19:40
#880102
The cylinder heads on the 1980 Kz750E1 still had the threaded bosses to install the top idler from the Kz650.
I don't remember what valve cover I had to use on the Kz750E1 head once I changed over to the Kz650 cam chain system. I think I used the 1979/1980 Kz650 valve cover.
1986 RG500G 2 stroke terror.
