Anyone know where to get these STUDS? Cylinder head
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • Banned
  • Banned
03 Feb 2023 11:55
#879744
Mine broke off from the head thats being cleaned.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Anyone know where to get these STUDS? Cylinder head
03 Feb 2023 12:05 - 03 Feb 2023 12:10
#879745
Last edit: 03 Feb 2023 12:10 by Warren3200gt.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Feb 2023 13:48 - 03 Feb 2023 14:00
#879751
A set of stainless studs and nuts.
z-fever.de/shop/de/product_info.php?info...n-edelstahl-6mm.html
If all went to worst case cenario, a M8 to M6 stud
z-fever.de/shop/de/product_info.php?info...ehbolzen-8-6-mm.html
A lot of head to the alumium is your friend to remove studs!!!
Last edit: 03 Feb 2023 14:00 by Scirocco.
  • carksz1b
  • carksz1b's Avatar
03 Feb 2023 14:11
#879752
At work i would drill a hole (1/16 to a 1/8 )all the though the stud,lay a flat washer then a 8mm nut,then use a wire welder and weld through your hole up to the nut ,let it cool then twist it out , it it breaks do it again.
  • urankjj
  • urankjj's Avatar
03 Feb 2023 14:15
#879753
Use caution when joining stainless steel and aluminum due to galvanic corrosion. Probably would be ok with exhaust studs but definitely use some anti-sieze.
The following user(s) said Thank You: Scirocco, Wookie58
  • DanMadBoy
  • Banned
  • Banned
03 Feb 2023 15:25
#879755
Whats a good way to get the old studs out? I dont want to break them off either.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Feb 2023 15:27 - 03 Feb 2023 15:28
#879756
So more the differnce between a precious metal (Stainless steel) and un-precious metal (Aluminum), a galvanic reaction (oxidation) between the metalls can occours. A anti-sieze is nessesary to build up a insulate galvanic boarder line. Thanks  urankjj  for the hint.
Last edit: 03 Feb 2023 15:28 by Scirocco.
  • urankjj
  • urankjj's Avatar
03 Feb 2023 15:50
#879757
I would saturate them with a penetrating solvent, (Kroil, Superzilla, or something similar). Let sit for at least 48 hours then remove. Good luck always.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
03 Feb 2023 16:34
#879759
I use a DeWalt 1/4" impact to remove small bolts and studs. It's really not powerful enough to break them off. But the impact, patience and Kroil will usually prevail. Using heat before attempting to remove the studs will prevent most of the breakage.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Dr. Gamma
  • Dr. Gamma's Avatar
03 Feb 2023 17:49 - 03 Feb 2023 17:50
#879763
If the exhaust studs are not bent, and the threads are in good shape and not stripped. I would leave them alone!!!
I have motors that are 40 years old with the original exhaust studs without any problems!!!
If it ain't broke, just leave it alone!!         Why risk breaking off a stud just because you wanted new studs.
1986 RG500G 2 stroke terror.
Last edit: 03 Feb 2023 17:50 by Dr. Gamma.
  • Mikaw
  • Mikaw's Avatar
04 Feb 2023 08:35
#879773
MDM is to only 100% sure way. Search it up. You might find someone close and not have to deal with it, otherwise welding a washer then a nut to the washer is my next best option. Drilling it out till you get to the limits of the threads then collapsing the remaining bolt in towards the hole , last I cringe to even suggest is an easy-out, to drill it out big enough to get an easy-out to work, you would be increasing the friction between the hole and the bolt. Beyond the MDM, any other method needs to have the first step, be soaking in a good capillary deep creep penetrate oil, with some heat and cool cycles. Good sharp taps with a punch on the broken stud will help, but don’t use a pointed punch, again like the easy-out you will be forcing material outwards and increasing friction. Good luck.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
04 Feb 2023 11:50
#879786
Is that the same as EDM
Which I have had done on my block to remove a couple busted off studs and bolts
DD
