Front sprocket
  • Mn kz
  • Mn kz's Avatar Topic Author
Front sprocket
20 Jan 2023 06:42
#879048
1980 KZ 1000 LTD
Trying to replace front sprocket. Not sure how to remove left engine cover.
Any help?
  • Mikaw
  • Mikaw's Avatar
Re: Front sprocket
20 Jan 2023 15:52
#879078
Just 4 bolts holding it to the cases, 2-m6 x 125 and 2-m6 x 70. Once removed the cover pulls straight out. The clutch cable and actuator stay on the cover.
The following user(s) said Thank You: Mn kz
  • TexasKZ
  • TexasKZ's Avatar
Re: Front sprocket
20 Jan 2023 16:17 - 20 Jan 2023 16:19
#879080
Don’t the foot peg assembly, starter cover and shift lever have to come off first?
page 60.    www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Last edit: 20 Jan 2023 16:19 by TexasKZ.
