Long term Z1 storage - how to reduce clutch pack sticking
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
07 Jan 2023 06:30
#878636
If one knows ahead of time that a bike will be mothballed for a few years, what are your favorite techniques to reduce or eliminate clutch pack sticking?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Long term Z1 storage - how to reduce clutch pack sticking
07 Jan 2023 07:10
#878638
Pull the clutch leveler and lock him with a zip-tie.
Turn the engine gears and clutch basket pack with the kickstarter every month.
  • krazee1
  • krazee1's Avatar
07 Jan 2023 07:18
#878639
Interesting question.  Would fatiguing the clutch springs be a worry if you disengaged the clutch with a ziptie at the lever?  At least if they do get stuck accessing the clutch pack to separate and lubricate the fiber discs is not a big deal. That gasket usually doesn't tear, and you don't even need to drain the oil if the bike is on the sidestand.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
07 Jan 2023 08:45
#878643
We've resurrected a lot of bikes and the bikes that had fresh clean oil in them when put away usually don't have a stuck clutch.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Jan 2023 10:04
#878645
Mike
What about the valve springs if the cam lobe is fully engaged, would they fatiguing?
  • Dr. Gamma
  • Dr. Gamma's Avatar
07 Jan 2023 10:47 - 08 Jan 2023 08:39
#878646
1986 RG500G 2 stroke terror.
Last edit: 08 Jan 2023 08:39 by Dr. Gamma.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Jan 2023 12:40
#878647
I suspect humidity also has a part to play, in the same way disc pads stick to the disc due to surface rust
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
07 Jan 2023 12:55
#878651
If it is to sit for several years, why not loosen the bolts (easy any pre-spring tension) and put note on the cover to tighten to spec upon getting back into use.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Jan 2023 13:16
#878652
If humidty or oxidation is the problem to stuck your clutch plates, fill your engine case with fresh oil up to the max. with no air left!
  • krazee1
  • krazee1's Avatar
07 Jan 2023 13:29
#878653
Mike
I just brought the fatiguing springs up for discussion, it is an ongoing debate in the firearms community as far as leaving magazines loaded for an extended period of time.  Not personally a believer.
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Jan 2023 13:47
#878654
So to be on the safe side, remove the clutch cover, spring set, all clutch friction and steel plates until reuse of the bike engine.
Storing a bike more than your persenal life span is bullsh*t. Bikes has to be driven as they are build for not for storage and look a like on display.
  • Kelly E
  • Kelly E's Avatar
07 Jan 2023 14:01
#878655
Mike
Mike
I was told that the spring sitting compressed doesn't hurt it, the repetitive motion is what wears them out.
1983 Honda CB 1100F
And more
