backside carter bulb
  • willemZ900
  • willemZ900's Avatar Topic Author
  • Z1B 4 ever
25 Dec 2022 05:36 - 25 Dec 2022 05:37
#878214
Is there somebody on de forum who can explain the bulb on the backside of the Z1 engine?  Why is it there and what is the need for it?
Last edit: 25 Dec 2022 05:37 by willemZ900.
  • Nessism
  • Nessism's Avatar
Re: backside carter bulb
25 Dec 2022 06:45
#878215
Is it a pry point to separate the crankcase halves, without marking the real sealing surface?
  • Warren3200gt
  • Warren3200gt's Avatar
25 Dec 2022 09:53
#878222
Don't know what it's originally intended for but it's handy to get a wooden drift on to split the cases.
  • martin_csr
  • martin_csr's Avatar
26 Dec 2022 06:29 - 26 Dec 2022 06:34
#878246
The KZ650 has a similar protuberance & the 81 manual says to split the crankcase using the 4 pry points.
Last edit: 26 Dec 2022 06:34 by martin_csr.
  • attachbee
  • attachbee's Avatar
03 Apr 2023 16:03 - 03 Apr 2023 18:09
#882439
It's simply a lifting point.
Last edit: 03 Apr 2023 18:09 by attachbee.
