Cams tensioner
- Maxbou92
Cams tensioner
22 Dec 2022 11:44
Hello guys, can someone tell me if the Cam tensioner(oem or manual) of a Kz1000 will fit on my Kz750 ?! Ive found one on ebay (manual one) and it says that he’s only for Kz1000 !? Like my Piston kit was supposed for kz750 1981-1984!!!!! But 1980 are the same as well!! So I wonder, if the Kz1000 tensioner fit on 750
thank you very much
thank you very much
Kz750e 1980
Re: Cams tensioner
22 Dec 2022 13:01APE lists the same PN tensioner for both the 750 and 1000, so they must interchange.Hello guys, can someone tell me if the Cam tensioner(oem or manual) of a Kz1000 will fit on my Kz750 ?! Ive found one on ebay (manual one) and it says that he’s only for Kz1000 !? Like my Piston kit was supposed for kz750 1981-1984!!!!! But 1980 are the same as well!! So I wonder, if the Kz1000 tensioner fit on 750
thank you very much
kzzone.com/tensioners.html
Also, if you look up the tensioner for a 750 on Partzilla, it shows the same PN used on a ton of different bikes, include many 1000's.
www.partzilla.com/product/kawasaki/99996...8d005d6f16010d2ca068
- Maxbou92
