when is it time to go oversized on valve guides?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
05 Nov 2022 13:56
#876429
not sure i have the best understanding, when is it time to go oversized on valve guides? i have one guide bore that is broke out on port side, there's a ridge within but the taper portion went away. but guide seems to be seated good and tight in bore. used loctite to assist. I know the circlip, to an extent, prevents the guide from being pulled through.
also, are apes better that kibblewhite guides? much thanks ia
1982 KZ1100D1
