81 kz305 valve adjustment makes extreme differance
- ckahleer
31 Oct 2022 19:11
Bike was getting hard to start and stalling at idle. I checked compression and found left cyilinder 30psi and right cylinder 150psi.
Found left intake valve adjustment tight, (no gap). loosened tappet screw about 1/4 turn to get proper gap. Compression increased to 160psi. WOW. I never thought a valve staying open by so little would cause such a big change in compression. Bike starts and idles as it should now.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
The following user(s) said Thank You: 82KZ305Belt
Re: 81 kz305 valve adjustment makes extreme differance
31 Oct 2022 19:27
Geeze man, there is this thing called "maintenance" for a reason. I'm truly stunned that people don't bother to follow the manuals recommendations.
- Nerdy
31 Oct 2022 19:42
Yep, that'll do it.
These are mechanical devices. They will work as long as certain parameters fall within a fairly broad range, as you saw (30psi vs 150psi), but they will work best when they are within a certain narrow range - as you also saw.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- ckahleer
01 Nov 2022 20:52Geeze man, that's quite an assumption.Nessism post=876254Geeze man, there is this thing called "maintenance" for a reason. I'm truly stunned that people don't bother to follow the manuals recommendations.
Any idea why a valve would go tight and remain partially open when valve gap was checked/adjusted and within spec just 2,700 miles ago. The nut on the adjustment screw was tight, so I don't think it slipped.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
