Noise
  • Fox
  • Fox's Avatar Topic Author
Noise
12 Oct 2022 13:58
#875488
Hello
do someone have an idea on what can be this noise please ?
thank you
youtube.com/shorts/YUJCZzhUrGY?feature=share
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Noise
12 Oct 2022 14:58
#875490
Less cam chain tention, broken cam chain idler or guide, valve clearance out of spec. It´s time to pull the valve cover and take a look under the hood.
The following user(s) said Thank You: Fox
  • Nessism
  • Nessism's Avatar
Re: Noise
12 Oct 2022 18:00
#875492
Sounds fairly normal.  As mentioned, I'd check the valve clearances, cam chain and tensioner, and exhaust leaks, which sound like engine noises.
  • kevski
  • kevski's Avatar
Re: Noise
12 Oct 2022 23:14
#875500
That's could be valve clearances or even cam bearing binding where possible head warp or wrong cam caps installed, lack of oil to outer cam shells.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Noise
13 Oct 2022 16:02
#875516
If you're talking about the ticking sound, it could be valve clearances. But the fact that they get worse on acceleration and are fairly consistent makes me think it's just an exhaust leak.
There are crush gaskets between the headers and the head, if you re-use these (we all do) they often won't seal as well, and get worse each time you use them.
1981 KZ750 LTD
