Ngk
- seminole1
Ngk
27 Sep 2022 13:40
Has anyone used an NGK Bpr7eix in their Z1.
RETIRED TRUCK DRIVER 42 YRS.
Re: Ngk
27 Sep 2022 16:20
Way to many letters. B8ES or W24 ES-U
- Darmah
Re: Ngk
27 Sep 2022 19:34
I stumbled on this. NGK B8ES alternative plugs. Might be interesting to some.
www.sparkplug-crossreference.com/convert/ngk_pn/b8es
The following user(s) said Thank You: gd4now
- kevski
Re: Ngk
27 Sep 2022 23:45
I use ngk bpe8s, the tip is about 1mm longer, they work great in mine, I also never buy off of ebay as there are way too many fakes out there.
- Elfarm98648
Re: Ngk
28 Sep 2022 05:47
Has anyone ever used iridium plugs in their motorcycle? Are they worth the extra money or not really?
NGK BR8EIX
NGK BR8EIX
Re: Ngk
28 Sep 2022 07:06My personal opinion is that unless you are running a high output/turbo motor there is no real benefit for the additional expenseHas anyone ever used iridium plugs in their motorcycle? Are they worth the extra money or not really?
NGK BR8EIX
The following user(s) said Thank You: Elfarm98648
Re: Ngk
28 Sep 2022 08:30Has anyone ever used iridium plugs in their motorcycle? Are they worth the extra money or not really?
NGK BR8EIX
I ran these in one bike for a while. They worked fine. Wound up removing them because I realized they are resistor plugs, and I already had resistor plug caps. No need for two different resistor elements in the circuit (even though the bike didn't seem to care.)
