KZ305 Top end work. Where to get parts?
- ckahleer
21 Sep 2022 14:34
The bike needs oil added every other tank of gas. Also oil is leaking from the head gasket.
I already have a top end gasket set, but have not found a source for piston rings. Depending what I find once all is dissembled, may need pistons, or over size pistons and rings.
I don't want to get stuck not being able to find parts once I have it apart. My searches haven't come up with these things.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Nerdy
Re: KZ305 Top end work. Where to get parts?
21 Sep 2022 14:47 - 21 Sep 2022 14:52
www.cmsnl.com/kawasaki-kz305a1-csr-1981-...partslist/64150.html
EDIT: Also this - https://www.[ebay].com/itm/385079982913
It looks like standard rings are readily available. The 305 was a comparatively low-production-volume bike, so oversize pistons and rings may be harder to find.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 21 Sep 2022 14:52 by Nerdy.
- Nerdy
21 Sep 2022 16:20
Forgot to ask: do you know you're burning oil that's getting past the rings? Is there blue smoke in the exhaust?
If so, you might be burning oil due to bad valve stem seals. I would look at them first, rather than rings, unless the bike has 50K+ miles (or has been abused). Viton seals are readily available.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- ckahleer
21 Sep 2022 18:21
Exhaust does not smoke. Oil is leaking around the head gasket,so it needs replacing. While I have the head off, I feel I should check cylinders, pistons, and rings. The gasket kit comes with valve seals, so they will get replaced. Since it is looking like I will not be able to source oversize pistons/rings, I'll keep my fingers crossed that everything is fine in that department.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- slayer61
- KZR FLAG RELAY CARRIER #62
22 Sep 2022 08:58
Ron Ayers? Partzilla. Pick yer poison!
- Irish Yobbo
22 Sep 2022 17:31 - 22 Sep 2022 17:32
If the exhaust doesn't smoke (excessively), I personally wouldn't worry about new rings/pistons unless there was something clearly wrong once the head is off. I'd suggest checking the bores for wear but otherwise leave everything below the head unless you're having other problems. If you are planning on checking pistons, be sure to get a new base gasket too. Chances are it's fine, and someone has just done a poor job installing the head gasket and the oil is all leaking, not burning. You can't tell for sure until you fix the leaks.
Once the head is off, don't forget to check that the head surface is flat, and that the deck is flat too.
I've always ordered from Partzilla, they've been pretty good for me.
1981 KZ750 LTD
Last edit: 22 Sep 2022 17:32 by Irish Yobbo.
- 82KZ305Belt
27 Sep 2022 20:49 - 28 Sep 2022 08:56
I don't remember my 305 smoking excessively when I rebuilt it because of a bad head gasket, but I found a scored piston once I got in there. And yer right, there are no oversized pistons or oversized rings available for reasonable prices, when they're available at all, which is very rare. I've been looking for a year. I've also looked for good cylinders that don't need boring, but those are equally unavailable. I had to order from Germany to replace my stock piston.
Someone in Canada sells 61mm rings for it. They should be on ebay. I bought some when I did mine. Everything else is also findable, as long as your pistons and bores are good
Edit: the rings are still on ebay but maybe ebay links aren't allowed. I tried posting it and it's invisible.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
Last edit: 28 Sep 2022 08:56 by 82KZ305Belt.
The following user(s) said Thank You: ckahleer
- ckahleer
28 Sep 2022 11:55
Yes, I ordered the gasket kit from that Canada seller. I still ride this bike almost daily, so I will be waiting until this winter to tear down the engine. I'll keep my fingers crossed that I woun't need over size pistons/rings.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- 82KZ305Belt
03 Oct 2022 18:54
Wish I could ride mine at all...
I have a belt I'll sell for a good price if you need a spare, if you have a belt drive. If so PM me
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- ckahleer
04 Oct 2022 07:46
Thanks, but I have chain drive.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
