KZ750 twin engine noise
- Bluescroft762
12 Sep 2022 11:53
Hi All - I have a 1977 KZ750 twin with 25000 miles on the clock. It makes a rattly whirry sound on the overrun (that is slowing down from 50 + mph with the throttle closed. I've adjusted camchain carefully and done the shims etc. The engine vibrates very little and pulls like a train. Has standard - fairly quiet - exhausts. Should I be worried? I'm not used to the racket these twins make - yet... Cheers Mike.
Re: KZ750 twin engine noise
12 Sep 2022 12:13 - 12 Sep 2022 12:14
Welcome KZRider
Did you check / lube /adjust the drive chain and inspect the sprockets
Last edit: 12 Sep 2022 12:14 by Street Fighter LTD.
- DoctoRot
12 Sep 2022 14:07 - 12 Sep 2022 14:08
If the carbs are not balanced well the primary chain can make a racket, but this is usually only noticable at idle. pretty common on these bikes. Also its possible the baffle in the factory exhaust thats come loose and is vibrating in the muffler.
Last edit: 12 Sep 2022 14:08 by DoctoRot.
- Bluescroft762
13 Sep 2022 03:35
Hi thanks for replies - yes it's a brand new chain and sprockets. But I should try and balance the carbs properly... It's definitely an 'inside' engine noise - I'm just not sure its normal or not!
BTW Is anyone else fed up with the robot verification thingy running out after a very short time! Cheers Mike
13 Sep 2022 08:14You have 2 approved posts now , so I believe the robot will no longer be any concernHi thanks for replies - yes it's a brand new chain and sprockets. But I should try and balance the carbs properly... It's definitely an 'inside' engine noise - I'm just not sure its normal or not!
As a new member you were not able to post with out each post being oked (Reviewed )
That is how we eliminate spam from our site
