help identify this broken guide please
- Gdailey2112
- 82 KZ1100D1
- z1kzonly
Re: help identify this broken guide please
03 Sep 2022 09:18
Later style cast iron guide, Kaw started using long wearing iron guides & nitrated valves with the later 100 engines, single guides are all over ebay, even some oversize, .002 -.004.
You need correct reamers and guide drivers to install correct. Plus you have to heat the head a little to expand. Might be time for an ebay head, lots of J-model heads on cheaper than the Z1/KZ heads for sure. I never followed the few years of the "Bath Tub" head different chamber pattern, drag bike guys like them to modify for older engine conversion
- krazee1
03 Sep 2022 10:11
IIRC they were referred to as "sintered iron", and started in 1978 for unleaded fuel use.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- Gdailey2112
- 82 KZ1100D1
03 Sep 2022 10:19
thanks to both of you
1982 KZ1100D1
The following user(s) said Thank You: krazee1
03 Sep 2022 14:20
The following user(s) said Thank You: Gdailey2112
- Gdailey2112
- 82 KZ1100D1
04 Sep 2022 09:33
yes there was that clip that came out with the springs for that valve and I'd found it right away, but didn't realize it was from the guide, thought it came from a valve seal lol
thank you Scirocco
thank you Scirocco
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
04 Sep 2022 10:07
lol my thumb looks like a toe in that pic
1982 KZ1100D1
04 Sep 2022 14:01
Those guides are still available new from Kawasaki. Also available from Partzilla and I bet CMS.
- Gdailey2112
- 82 KZ1100D1
04 Sep 2022 21:53
thank you very kindly, sir
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
06 Sep 2022 11:42
burning question, should i replace the broke cast iron guide with a bronze guide so i don't have to fart around with heating the head and cooling the guide?
1982 KZ1100D1
- Nerdy
06 Sep 2022 11:51
I'm wondering if you could dunk the guide in liquid nitrogen and then simply drop it into the unheated head.
The LN will make the guide MUCH colder than any freezer could ever imagine, but don't hit or drop the frozen guide because it will shatter.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Gdailey2112
- 82 KZ1100D1
