Thinking of buying a "Polished Stainless Allen Engine Bolt Kit" for my KZ400
- Jon99
25 Aug 2022 14:19
This may be a stupid question, but is there any reason not to do this? That is, replacing the old bolts with allen bolts?
- JR
Re: Thinking of buying a "Polished Stainless Allen Engine Bolt Kit" for my KZ400
25 Aug 2022 15:19
Go for it. No reason not to. Old bolt heads get mangled. I did it years ago. Stainless steel ones.
- Nebr_Rex
25 Aug 2022 15:25
It is a good idea since sometimes the head of the screw is knackered.
This is because people think it is a phillips head when actually it is JIS [Japanese Industial Standard].
By selling your original screws you can recoup someof the cost.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Irish Yobbo
25 Aug 2022 16:28
+1 Good idea - one of the best value upgrades you can make.
There are two reasons not to do this. One - the bolt heads will protrude a but more - I've never had any issues though.
The second is galvanic corrosion - aluminium and stainless steel are sufficiently different that galvanic corrosion can occur between the two metals. This is more theoretical than anything else - if we were talking about aluminium fasteners on large stainless pieces it could be a concern, but in practice stainless fasteners on aluminium isn't an issue.
1981 KZ750 LTD
25 Aug 2022 16:48 - 25 Aug 2022 16:52
Ceramic or copper anti size lube will block the galvanic corrosion between highest and lowerst level of the un-presious/presious metal.
Last edit: 25 Aug 2022 16:52 by Scirocco.
The following user(s) said Thank You: 750 R1
- Nerdy
25 Aug 2022 18:16This may be a stupid question, but is there any reason not to do this? That is, replacing the old bolts with allen bolts?
Functionally? No. The Allen fasteners will be better in pretty much every way.
Visually? They will not look correct/original, but if you're not concerned about that then no worries.
I picked up a set for a 400 years ago and never used it; now it will go on a 440.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
