Cam recommendations
  • lewisj
  • lewisj's Avatar Topic Author
Cam recommendations
21 Aug 2022 15:47
#872625
What is a good street cam for a Z1 1075cc rebuild.  Looking for good all-around performance , not racing.
Thanks !!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Cam recommendations
21 Aug 2022 16:18
#872627
Which cam,intake or exhaust?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
21 Aug 2022 17:15
#872628
My dad's '74 Z1
'00 ZRX1100
  • lewisj
21 Aug 2022 20:28
#872631
Great info DOHC!!   Thanks for taking the time to help!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
  • zed1015
  • zed1015's Avatar
21 Aug 2022 23:28 - 22 Aug 2022 08:15
#872634
407 / 410 Lift fast road cams are what you need.
New ones available from Yoshimura, PSP ( Andrews spec from Pitstop Performance) . Web cams ( Orient Express and Schnitz Racing ) etc.
Last edit: 22 Aug 2022 08:15 by zed1015.
  • z1kzonly
  • z1kzonly's Avatar
22 Aug 2022 07:14 - 22 Aug 2022 07:21
#872644
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration ]
Old Kaw cams are like gold! Kenny Harmon, Andrews, RC Engineering, Pops Yoshi,
.395" - .410"
Here you go! $250 on ebay right now! Taking offers too. Call him direct, he deals with his business cheaper than ebay.
Andrews 2X drop ins, no valve bucket modification needed, stock type piston domes, (I do see 72mm on yours)
Johnny Bova in Ohio. (Johnny's Vintage)       OINK would get $400 for these!
Last edit: 22 Aug 2022 07:21 by z1kzonly.
  • z1kzonly
  • z1kzonly's Avatar
22 Aug 2022 07:26 - 22 Aug 2022 07:30
#872645
No eBay APP ID and/or Cert ID defined in Kunena configurationAll right? I have pasted ebay links in the past!
Now I have no clue?
I tried 2 times with the links?
Just search Andrews 2X Kawasaki cams on eBay, it will come right up.
Someone better buys these!
Hey Lewisj your 1-1/2 hours away, John is in Wadsworth.
I'm done and selling out! Or I would have just made the deal now.
Last edit: 22 Aug 2022 07:30 by z1kzonly.
  • Mikaw
  • Mikaw's Avatar
22 Aug 2022 09:10
#872646
Looked up the spec on the 2x, very similar to the RC 388’s I bought a couple years ago. Looks like a good cam for a stock 1015 bore with 10 to 1 compression.
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
25 Aug 2022 16:53
#872859
Running Andrews 2X in my 1075 right now...runs great and did not need to go crazy on fancy valve train mods...One caveat is if you intend to kickstart and are planning more than 10-1 compression, maybe something with a little more overlap...it's a bugger to kick
  • TexasKZ
  • TexasKZ's Avatar
27 Aug 2022 06:17
#872932
APE sells a nice .410 lift set.
kzzone.com/cams.html
