1982 GPZ750 rod bearings
- 750 R1
17 Aug 2022 18:45
Hi Guys. I'm chasing rod bearings for my 1982 GPZ750 R1 engine and can't seem to find any, I've contacted Kawasaki here in Australia and they have nothing.
I have sent an email to a friend in the UK asking of availability there, but thought I'd ask here as well ..
Thanks
Thanks
- Ojisan rider
Re: 1982 GPZ750 rod bearings
17 Aug 2022 19:03 - 17 Aug 2022 19:15
If I'm not mistaken, I got mine just few years back through evilbay. Not sure how many and what you need, but you WILL pay for them. Try it with part # and see if any turns up. I know our rod bearing is unique due to hole at upper bearing. maybe you can use one without it?
I haven't tried Yahoo Japan auction, but when I was looking for it, it did turned up from time to time.Again, you'll need to use part # to look it up. Their's one was cheaper if I'mnot mistaken, but I needed in a hurry so looked in US Evilbay.
EDIT: Just went to these guys and seems as they still have some. I go there from time to time to get parts that's unavailable. But let me warn you. After you pay them and that dreaded message from the seller telling you "parts not available" may be on the way. happened to me several times already. They will refund you right away, but thought I mention that.
www.megazip.net/zapchasti-dlya-motocyklo...703680-584728-584728
Good luck.
Good luck.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Last edit: 17 Aug 2022 19:15 by Ojisan rider.
- Daftrusty
17 Aug 2022 19:56
750 R1- Are you looking for the rod bearings with the hole for the piston squirter drilled in it?
If so, you “may” be able to get by with using the standard upper bearing shell and drilling the hole yourself.
The rods with piston squirters were only used on certain 750’s from 82-83 before being discontinued. So bearing for those have been very hard to find for years.
I considered using squirter rods on my engine build but I honestly could find a complete set of rods, much less new bearings.
Food for thought
Food for thought
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
- 750 R1
17 Aug 2022 22:41750 R1- Are you looking for the rod bearings with the hole for the piston squirter drilled in it?
Food for thought
Gday Rusty, yeah, no problem drilling out the bearings if I have to. It seems that the bearings without the squirter holes have different colours and part numbers, now I have to workout which one correspond to the part numbers I have, because I just looked at the link Ojisan rider posted above and the part numbers and colours are different to what's in the Kawasaki workshop manual I have for the 1982 GPZ 750R1....
I need 8 black Kawasaki pn 13034-051 and 2 green Kawasaki pn13034-050. I want the 2 extra greens as 2 of my crank bearing journals measure right at the transition for the next size bearing, just to be safe..
- Daftrusty
18 Aug 2022 05:26
I believe as long as you use the connecting rod and crank “0” or “no mark” decision tree, that will lead you to the standard bearing shell color codes you need. (Which is what I believe you have done)
As Kawasaki didn’t make special cranks for the gpz, so it stands to reason they used the same journal measurements and markings. (I know for certain that Kawasaki used the piston squirter rods in other models for a time, but the oiling passage was not drilled out. So those would have used standard bearings shells.)
Fit them up in the rod, torque the caps on, drill the oil hole, chamfer the hole in the bearing surface then bolt them up.
1990 zr550
kz750e
kz750e
- 750 R1
18 Aug 2022 15:27
Hi rusty, yeah, I did the mark,no mark thing then used a dial gauge to the journals, so The measurements and part numbers are good. I'm having no trouble getting the mains,just the rod bearings are a problem. I may have found some in the UK but they're bloody expensive. Thanks for your help...
- scubaanders
18 Aug 2022 23:27
Cmsnl shows positive stocks for the big end bearings for the 750R1. They have never let me down, but they are 10EUR a pice
brgds Anders
brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- 750 R1
19 Aug 2022 21:12I just bought parts from CMSNL and was going to get the bearings too, I'm getting the crank main bearings from them but they have no black big end bearings, that's what its showing at my end... Can you post a link please Anders ? The part number is 13034051 black bearings , It's also saying 18:50 euro for them... Link below
www.cmsnl.com/kawasaki-kz750r1-gpz-1982-...55.html#.YwBeZHZBzIV
- Ojisan rider
20 Aug 2022 00:16
Found this under KZ700. If they actually have it, I'm not sure. You can always message them.
www.megazip.net/zapchasti-dlya-motocyklo...637944-584729-584729
- 750 R1
20 Aug 2022 16:17Thanks for the link, it still doesn't really help, even though there may be bearings there that may fit, they are Black, brown and Blue, I'd have to know the bearing specs for the 700 to make sure I was getting the correct bearings, they have different colours and part numbers , I'm after black and green...Found this under KZ700. If they actually have it, I'm not sure. You can always message them.
20 Aug 2022 18:16 - 20 Aug 2022 18:20
Last edit: 20 Aug 2022 18:20 by Scirocco.
- 750 R1
21 Aug 2022 01:47
Thanks Scirocco, I found 6 blacks in the UK and snapped them up so I'm only chasing 2 blacks now, 50 Euro shipping for those ones in the link..!!
