KZ750E correct shift fork installation positon on shift drum?
05 Aug 2022 10:37 - 05 Aug 2022 12:56
A member in a german cafe racer forum ask me for help about the correct shift fork position on the shift drum.
The KZ 750 service manual (750turbo.com) shows contradictory representations of the fork position.
So what is correct position?
EDIT: It´s a 5 speed transmission!
AFAIK this position is correct:
or this FSM position:
Last edit: 05 Aug 2022 12:56 by Scirocco.
- Warren3200gt
Re: KZ750E correct shift fork installation positon on shift drum?
05 Aug 2022 11:54 - 05 Aug 2022 12:03
Looks to be the same casings as a 650. So here's pics of the correct position. Looks to be fsm position.
Last edit: 05 Aug 2022 12:03 by Warren3200gt.
The following user(s) said Thank You: Scirocco
