Z650 1978 ignition timing
  • dmax68
  • dmax68's Avatar Topic Author
03 Aug 2022 14:09
#871627
greetings to all, i have a doubt about the ignition timing of my 1978 z650.
the gasoline we use today has 95 octane while in the 70's and 80's it had 97 octane.
With gasoline available today, to regulate ignition times, is it advisable to postpone them a bit?
  • zed1015
  • zed1015's Avatar
Re: Z650 1978 ignition timing
03 Aug 2022 14:48
#871630
Stock timing will be fine.
The following user(s) said Thank You: Warren3200gt, dmax68
  • Mikaw
  • Mikaw's Avatar
03 Aug 2022 17:22
#871641
I run 93 octane with a smidge advanced. No issues.
  • Nessism
  • Nessism's Avatar
03 Aug 2022 18:32
#871645
Where in the world are you?  There are different octane rating methods in different parts of the world.  I suspect you are in a country which uses the RON method, which is a different rating method than what the USA uses, for reference, and the octane numbers are higher for the same fuel.  At any rate, a couple of octane rating points won't matter either way if your bike is tuned properly.
  • dmax68
03 Aug 2022 19:35
#871652
 thanks for the immediate answers, I'm writing from Italy.
I had a doubt even if in fact the bike works perfectly.
