KZ400 Shifting
  • nebraskajeff
  • nebraskajeff's Avatar Topic Author
KZ400 Shifting
24 Jul 2022 19:26
#870961
Have a new to me 78' KZ400a, one family owned with about 4200 miles on it.  I'm in initial stages going through the systems and am noting it kind of shifts like a tractor, pretty harsh.  I have owned and still own other KZ400s and have never experienced this before.  Bike has had an oil change BTW.  Any thoughts?  This is the old style 400 engine with the different top end, not the later style that started on the 78' b models if this makes any difference.  I should mention shifter not bent, don't believe this bike had hard use.  Thanks
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ400 Shifting
24 Jul 2022 20:14
#870963
How does a tractor shift?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ400 Shifting
25 Jul 2022 01:06
#870970
Is the clutch correctly adjusted ?
The following user(s) said Thank You: nebraskajeff
  • nebraskajeff
Re: KZ400 Shifting
25 Jul 2022 04:46
#870973
This is next on the list.  Maybe clutch plates are sticking as well.
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ400 Shifting
25 Jul 2022 06:03
#870976
Yup, clutch cable adjustment would be my first suspect. Does it have motorcycle specific oil (JASO-MA rated), without any additives?
  • Nerdy
  • Nerdy's Avatar
Re: KZ400 Shifting
25 Jul 2022 07:23
#870982
If it had additives it would probably shift better.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: KZ400 Shifting
25 Jul 2022 11:06
#870998
It could also be the rubber pucks inside the clutch.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
