turns over but intake valves stuck open
- 82KZ305Belt
22 Jul 2022 16:39
I need new cylinders and found a very low miles engine in this condition. No compresion obviously, so obviously I don't know what condition the bores are in, so is this a complete waste of time to consider? I'm not sure what the stuck valves might mean for the condition of the cylinders, or if anything can be reliably assumed from it. I'm not even sure how it can turn over with stuck valves
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
Re: turns over but intake valves stuck open
22 Jul 2022 17:00 - 22 Jul 2022 17:03
If a valve is actually stuck, the crankshaft could not make a full revolution unless the head of the valve is broken off and bouncing around in the cylinder. I would pass unless I could get a bore scope in the cylinders to confirm their health.
I suppose it could be a sticky valve that is being pushed almost closed by the piston. I would still wqnt to look inside first.
Last edit: 22 Jul 2022 17:03 by TexasKZ.
22 Jul 2022 17:50
Bent valves most likely. Time to pull the head.
- 82KZ305Belt
22 Jul 2022 18:07How do valves get bent on a low miles (<5000) bike? Neglect? Abuse? Don't really care about the valves but if it could indicate piston/bore problems, I care a lotBent valves most likely. Time to pull the head.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- howardhb
- God, I trust
23 Jul 2022 00:06
Abuse most likely, whether intentional or mistaken... down-shifting, instead of up-shifting gears at max RPM,
causing over-revving, whereby the resulting velocity / inertia of the valves is greater than the valve spring's ability to maintain the valves following the profile of the cam lobes, and out of eachothers way, and, out of the way of the pistons!
H.
H.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
- 82KZ305Belt
23 Jul 2022 07:35
Owner now says the intake valves do not move, so if it is truly turning over that must mean they are broken off. Sounds like cylinder damage is likely too. Scratch another one from the dwindling list...
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
