1982 Spectre centre bolt on bottom - where does it go into?
  • ErlingW
  • ErlingW's Avatar Topic Author
  • Away
23 Jun 2022 17:37
#869268
Hi all!
Going to do a mock-up assembly of my used spectre exhaust manifold, to fit it to a GT750 - same downpipes, same engine case.
On the picture, You see the large hole on the bracket on the cross-over pipe. Where does this bolt end up?
Are there also any washers and dampeners I have to look for?
Manifolds are being cleaned to bare metal - inside and outside, any dents repaired, and coated in ceramic black gloss finish. Quite a job!
Thanks in advance!
ErlingW in Oslo, Norway
  • Nessism
  • Nessism's Avatar
  • Away
Re: 1982 Spectre centre bolt on bottom - where does it go into?
23 Jun 2022 17:45
#869269
A threaded hole on the oil pan.
The following user(s) said Thank You: ErlingW
  • ErlingW
  • Away
23 Jun 2022 17:55
#869272
Thank You!
Then, I'll just put the lower case and oil pan into the frame, to figure out how to adapt this to my bike.
ErlingW
  • TexasKZ
  • TexasKZ's Avatar
24 Jun 2022 05:18 - 24 Jun 2022 05:24
#869285
Here is a very crappy diagram showing all the bits and bobs connected to the Spectre exhaust system.
www.partzilla.com/catalog/kawasaki/motor...re-kz750-n1/mufflers
Here is a much more gooder diagram of the GT system for comparison.
images.cmsnl.com/img/partslists/kawasaki...ae0369e1140_1690.gif
Last edit: 24 Jun 2022 05:24 by TexasKZ.
